injectors not working
Car  1.2 clio/clio sport
Hi all, right we have a 1.6 clio and we have just put the engine back in but we have found that there is no fuel getting into the cylinders. we have put it down to the vacuum valve on the fuel rail not working we belive that its not opening the valve and allowing fuel into the injectors does any body have any surgestions or know where the vacuum pump for the fuel system is.
cheers
josh
Pop the fuel line off at the rail, if your not getting fuel, it's a supply issue. The valve you speak of is the pressure regulator. This has nothing to do with no fuel.
There is a red button on the passenger suspension turret. Press this, it is most likely the cause.
If there is fuel from the line when it turn the Ign on, then its probably immobiliser related.
We pressed the red button down and this has no effect on it and there is fuel coming out of the feed pump but then if we take off the return pipe nothing comes out ?
There is a steady flow from the input line and i dont understand what you mean by primed.
there is the pictures :D
Nice one thanks ever so much its started first time, this is the first time we have done any think like this so its a big learning curve thanks again :D
