injectors
Car  ph2 172,2010 transit
my ph2 172 is running rough think it might be injectors. took the plugs off and all for plugs are getting power. then with car running removed plugs 1 by 1 no1 almost stalled no2 made no difference no3 almost stalled no4 made no difference swaped no 1 and 2 injectors around and tried again but everything stayed in the exact same order. !!!
any one else experienced this ? if it was straight forword i would just replace the injectors
if you changed the injectors but the problem didnt move cylinder then it's not your injectors... get a code reader on it... could be something you're not looking at, like your lambda sensor causing it to run rough
ok thanks. is there an easy way to check the lambda sensor ? with out a code reader as i dont have one ??
many thanks
swap the two around, one of them is only used for diagnostics...
does the car feel rough bellow 4k rpm only?
scared to rev it high at all in case it blows ha ill try and swap them round at the weekend and ill let you know.
thanks very much for the tips
