does anybody have or no anyone that has the dimension for the inlet manifold. need it for university project as i am designing it in solidworks. any help would be appriciated
cheers ric
cheers ric
Easy enough to measure the wall thickness with a mic. The casting will have a fairly uniform thickness and is probably about 3mm or so. Most stuff we cast is about 3mm wall section. The only way you will find out without measuring it is if someone has a working drawing for it which would be confidential anyway.
