Inner track rods
Car  LY R26 #288
I think I might need some track rods. Are the ones from eurocarparts the right ones for a 182 with cup packs?.
There seems to be a couple of different lengths to choose from?.
I have an SMI steering rack.
Oh that's good then. I might replace them first see if it solves the problem. Im dreading them inner ones!
Done my track rod ends today. Cost plus 10% is handy. £16 all in for them. Thought my rack was gubbed but a had a broken spring so got that replaced today. 85 + vat from Renault!!
I discovered a bad clunk coming from the front wheels, turned out one of the track ends was so nakerd the hub nut was lose by about 1mm causing that clunk.
I replaced both ends and had the wheel alignment carried out, still having the noise, turned out this time the drivers alignment securing nut had worked its way lose.
After that i had someone hold the steering wheel and there was no movement left to right, so yeah do the easiest options first. I would have had to get a garage to do the work what with the tool being needed etc.
Yeah I remember reading your thread mate.
Definately got noises when I shake the wheels side to side.
Seems to be both sides. And when traveling over rough road surfaces the steering wheel gets pulled left and right
