The correct tools that cost around £50??
how can I tell if the inners are worn?
Lemfoder is a good make. I have used a good set of water pump pliers and stilson's before to do them so the 32mm tools not critical although I got one. Aftermarket parts are usually a different sized knuckle so the tool is useless.
You make the actual tool thinner. If you search for a 32mm viscous spanner, it needs to be similar width to that.
Easy to do.
http://www.halfords.com/webapp/wcs/...&productId=214258&categoryId=165469&langId=-1
this what you mean??? Until I searched I thought you meant shave the other way haha.
You need to narrow the outside of the jaw so it can get in there.
Cant remember prices now, dont think it was much more than that, email/call Adam.
