install cruise control in to my ph2
  Renault Clio 172 Ph2
Sports and Dci only iirc and you may or may not need a uhc reprogram.
theres a few threads of people doing it, obviously you'll need the steering wheel, the cc/sl panel switch, and then this can only be done if the wiring connector is there behind the headlight height/ESP switch panel to the bottom right of the steering wheel.
Check the threads and they'll be your best bet of people's (un)successful stories!
hope this helps
