Installing a floppy drive
Connect power.
Connect Cable.
Check in BIOS to see if it's enabled or disabled. If you didn't have one to start with, it's probably disabled. Set to 1.4MB Floppy drive in BIOS so it's now enabled.
Save Changes and Exit.
Boot as normal.
  Revels Mum & Sister
Also you get the cable on the right way round at the floppy end. You can plug it in both ways round. It wont harm it. Basically if the light on the floppy drive is constantly lit when you boot then its on the wrong way!
