Installing apps in Kubuntu
Car  Dirty E91
Just installed Kubuntu onto a PC, I can't see how I am suppoed to install Bittorrent. I've downlaoded the app, unpacked it but don't know what to do next, there is little or no info on this that i can find.
Okay, the easiest way for you to do this is via a terminal.. its not the big scary monster people think it is, just follow this and you will be fine !
Open a terminal click applications then accessories then click terminal.
Now type the following (you will be prompted to enter your password)
Code:
sudo kdesu /etc/apt/sources.list
This will open a text editor.. scroll to the very bottom and paste this in.
Code:
deb http://ppa.launchpad.net/bortis/ubuntu hardy main
deb-src http://ppa.launchpad.net/bortis/ubuntu hardy main
Now save and close this file, you have just added the repositories you need to do a simple install.
now in the same terminal type this.
Code:
sudo apt-get update
and finally type this
Code:
sudo apt-get install transmission
Congrats, you now have transmission installed, and there should be a shortcut under applications/internet/transmission.
Any probs let me know.
Cheers for that!
Just managed to do it using the Adept installer, seems it hadn't updated itself.
Is transmission better than bitstorm lite?
Havent used bitstorm lite, I found transmission and have stuck with it as it does everything I need it to.
