Intake air temp sensor P0110
  182 FF
Hi all, recently bought a 182 to get into trackdays...
It's popped up the EML light and has started idling lumpily. Code reader suggests that it's the intake air temperature sensor code P0110.
I've replaced the IAT sensor and still have the same problems. When live logging the intake temps it jumps between -40 degrees and about 10 (actual ambient temp) suggesting something is up with the sensor or wiring. The old temp sensor and the new one I've checked and they are varying their resistance as they should do throughout different temperatures.
I had a search and didn't find much at all about these sensors causing problems...
Anyone experienced similar and found a fix?
