Interior lighting problem
Car  Clio 1.2 16v
Hello! right, when I turn on my lights the all the lights go to dim e.g. clock speedo and that then the fan lights don't light up at all but when my lights are off everything works fine any ideas on what could be the problem cheers :)
The backlights are meant to dim. If they were too bright, you'd not be able to see out the windows at night - night is when you have your lights on...
I've still no idea what the fan lights are ?
Have you adjusted the brightness .. right hand side, lower dash.. should have 2 dials - one for dash brightness and the other for levelling the headlights.
I think he means the lights in the heater control panel.
But then if the lights are off, the lights in the heater panel should be off, so how can they be working fine when the lights are off?
They dim that bad you cant see anything unless you really try and look, and I only have a headlight level adjuster
Fan lights - heater panel you may need some new bulbs they are T5 cap less bulbs or just buy 'dashboard' lights and as above try adjusting your dimmer on the panel
The clocks shouldn't be illuminated when the lights are off either :S
Unless you mean by 'lights off', that the sidelights are on.
The clock as in the time clock not speed clocks, but I've just remember, was wiring up fog lights earlier and put the switch where the dimmer adjuster is on some models but behind was a random adaptor just connected to the plastic, my dad broke it off by accident think that could be to do with it? Cheers people anyway
Yes, but they've just been wired into they're own circuit, only thing I did to the electrics already there was take that thing out because it looked as though it didn't do anything, bit stupid really.. haha
