massiveCoRbyn
Several
As above really?
My '53 172 Cup has a little bit of play in the front end. You can't feel it on smooth roads particularly, but on bumpy roads you get a lot of fight through the steering under acceleration. If you wobble each of the wheels by hand, you can feel/hear a little clunking in the steering. It's worse on the nearside I think, but not by much. The car had new TREs quite recently, which made no difference.
Not had a chance to get it up in the air and try and work things out properly, but I just wondered if steering rack wear was a common issue with these, or whether it might just be the track rods themselves.
Car is hardly low mileage at 120k. Not sure I fancy changing the rack, as I assume it's a subframe off job!
