Nope you could have a look at the 1.4 throttle body but I dont think it would fit. May be better trying a 1.4 manifold a and throttle bodie but Ive no idea of the size of them
dont know if you can do what can be done to carbs.
you can try modifying your throttlle shaft and throttle plate screws. This screws disrupt air flow so you can take them out and weld the plate through its holes using TIG so it wont bend the plate and shaft. Also you can cut down one half of the shaft width.
This job should be done by a competent machine shop.
