Is This Normal
Steve
  ST3 8.5
From cold for the first mile or two my car is hesitant, holds back, generally feels sick.
As soon as temp moves up shes fine and dandy????????????
  Chocolate Bar™
mine is like that. i normally leave it ticking over for about 30seconds in the morning before going anywhere (whilst i sort my cds and crap) and it drives much nicer.
probably all a big placebo tho.
  VaVa
Yup, it's a 'characteristic' of the car/engine. All 172/182 variants are the same. It's due to emissions control iirc.
  Golf GTI 1.8T
of course it is, even mine does it. do what middo said let it tick over for 30 secs this helps it, and remember most engine wear is caused within the first 10 mins, so make sure youve got a nice warm engine before that pedal hits the floor!
  182 - conneries de c
My 182 is like that in the mornings. Its hesitant especially from 1st to 2nd.
I let mine warm up for a minute or two while opening the gates to the drive.
Seems to work because its much smoother with a little warm up.
  2004 1.2 Dynamique
I've been getting this lately, you would expect it ona 10 year old car though as i've got
  Ziel Nurburgring
Isnt it because while cold its leaned out and once warm its fine as the ECU then gives you full fuel? Leave run for a few minutes before heading off to get a bit of warmth in it.
Im sure you know what its like trying to bend in a dry one, once everythings warmed up it all goes smoothly.....
  Golf GTI 1.8T
combination of things, but I'm pretty sure ever car clio or not will do something similar. motorbikes are even worse and you should let them tick over for 3 mins before riding.
  Megane225FF
teehee...
"Im sure you know what its like trying to bend in a dry one, once everythings warmed up it all goes smoothly....."
"..you should let them tick over for 3 mins before riding"
KDF
  Audi TT Stronic
It is because the ECU is programmed to be very fuel restrictive until the car heats up a bit in order to pass the Euro emissions tests, normally about 2-3 minutes will do the trick and you will suddenly notice that all hesitation is gone, its normally about 2.5-3k rpm that you feel it most
  Clio 197
Totally normal...
Just for fun, open the windows and take it to 3krpm in 2nd gear (30ish) (very gently), then take your foot off the gas... "p :quiet: op pop pp opoppp p p ppoop".
  Mégane RS
on my brothers new 2lt megane when its cold and he starts the engine the car will rev slighty higher than usual for 30 seconds to preotect the engine in cold conditions, i usualy let my car idle for a bit before i drive it
