i hate this "i want it cheaper mentality."
you get what you pay for. cheap = bad contention on the ISP's pipes + shaping/throttling.
This is the way ADSL works....It's what's called a "contended" service.
Based on current BT pricing levels, a 622Mbps central "pipe" costs an ISP around £160,000.00 per month. On an un-contended service (i.e. all users are guaranteed their full 8meg at all times - actually 6.8Mbps is the maximum speed from ADSLmax), this works out to around £1,750.00 per customer, because a 622Mbps pipe can only fit 90 odd users running at full speed.
Based on the assumption no customer wants to pay £1,750/month for their ADSL connection, the ISPs share it out between their customer base.
If they put 5,000 users (instead of 90) onto a single pipe, the cost (per user) drops to around £30/month per user.
As you're with an ISP that charges an awful lot less than £30/month, it's fair to assume they are cramming more than 5,000 users onto a single pipe (probably more than 20,000 users, bringing the cost they have to pay BT down to under £8/month).
The lessons to be learnt here: -
1. Don't go with the cheapest ISP you can find (unless you're happy to put up with rubbish speeds during peak demand).
2. What do you expect for £10/month?
what about the ISP's that are on unbundled LLU?
