right i think my temp sensor is fcuked!when at idle it starts a 900 rpm then dips all the way down to a stall then picks back up again,it doesnt do this all the time tho, i have also noticed that it has been popping a lot more,is this due to the temp sensor giving the wrong reading and using more fuel?any ideas?
or is it the idle control valve?
its on a 16v by the way.
also my fuel pump connector that sits on top of the tank keeps coming loose,sometimes i have to hold it on to make the pins contact inside so that the engine will start,anyone else had this problem?
