It’s yellow
  197 Cup
Looking much better,
you need to get them blasted.
From this,
To this,
Ant1
Brembo! Brembo! Brembo!
Sunflowers out and about. First time since picking it up. Runs well now, done most bits but still have some more to do. New B14s to fit, horn to sort, oil leak to sort, interior deep clean and fit better front seats, tracking. Oh and rear centre box, need a stronger joining clamp to hold the thing in place so it actually performs like a stealth exhaust visually ??
Ant1
Busy morning for the sunflower. New BS14 coilovers fitted, inner rod and rack ends. Original cold air feed fitted and finally sourced and fitted a set of mint front arch to bumper liners. As suspension was off I whipped a set of eibach camber bolts on. Alignment booked for weds! Happy days!
mintno1
  Ph1 172 / Mk1 Valver
Love this colour, you thinking of doing anything else externally?
mintno1
Pfft. I have two in garage, problem is in the future people will be gagging for the original. Same as the R5 turbo scene.
Would look great on 16" F1's if you could get a set, cup spoiler easy to change if you fancied it for a while
Ant1
Alignment time! 1.5 neg on the front & 1mm toe. Feels so much better on the B14S. Much more suited for road use.
Night and day difference from when I picked this car up.
Just need to fit the replacement rear exhaust clamp this afternoon so I can raise the back box.
Chris V6 255
  V6 255, 182 Trophy
Looks awesome!
Really miss my sunflower even though it was a shed [emoji23]
Ant1
Some small updates, gathering parts ready for the spring.
I have a mint bulk head panel, new set of mats, standard exhaust, mint rear seats and three mint passenger seats to make one good driver and have a matching passenger.
Also have a set of 10mm rear axel spacers to fit which I should be able to fit whilst car is in garage.
Really looking forward to getting this out, finished and used in the spring.
  Ph2 172, 106 Rallye
You've had me looking for a sunflower ph1 for months now. That's perfect (although I prefer it on the other wheels)
Ant1
Once I have recovered from man flu I will paint the hub part of the discs, bleed the brakes, and bolt the wheels back on. Than I can roll it out the garage and sort the seats ?
