ITB 45 vs 48mm
  Clio RS Mk2 PH1&PH2
Hi, what is the maximum power that I can get from a 45mm itbs and 48mm the engine (F4R 730) Iam building will run at 7800 rpm maximum. Thanks
Kev@KAM
ClioSport Trader
  Badass Toyota
You should match the throttlebodies to the engine spec. What cams, compression, headwork, exhaust etc etc. Its not a bolt-on-gain-x-bhp type of modification.
  dan's cast offs.
I'd say would be fine with 45s with running standard comp but if you want to throw 48s on then not like it would be an issue with them.
  Clio RS Mk2 PH1&PH2
Thanks for your feedback, I will assembly with a borrowed 45mm jenvey inlet to start. After I will decide which one to go. I will post the dyno graph ASAP :)
