ITG Panel or BMC CDA??
  V6 230
Hi, I currently have a ph1 172 with an ITG panel filter but am after a bit of induction noise without having an open filter :)
I am not expecting any power gains but just wanted to know if the BMC sounds much better than a standard airbox with ITG filter.
I know the Maxogen is the daddy but I dont have megabucks to spend on this so ideally around the £100 mark
Cheers for any suggestions in advance :)
Tom
  EV (s)
Panel.
Pull the hose out the box when you fancy some noise.
  phase 1 172
i`ve got a bmc kit but instead of a cold air feed i`ve connected a samco 90degree bend on the end thru the gap behind the head light then angled the 2 standard feeds infront of it
sounds good and no where near the heat soak
  phase 1 172
yeah i still hav the low down talk but also hav the nice grumble around 2000 revs then as the cam kicks in it roars
i wud say its not far off a hillpower for noise which is good conprimise
  LY 200
Iv got a BMC mate......Nowhere near the noise of an open kit but still sounds grunty whilst at least keeping the same performance!!!
Looks a treat under the bonnet aswell.
Dooby
  172 Cup
I had a bmc and found it lost power over the standard box, i now have a hillpower and its much better.
