Itunes help on imac !!!!!
  Mk1 MX-5 next summer
Right f**k knows wat i've done but...
For all the imac users who have the 2 buttons either side of the mighty mouse that extends and spreads everything out. When i click itunes it loads up but is off the damn screen, i press the too expander buttons and the itunes screen pops up but whatever i do it disappears off screen again so i cant play music etc or even use it.
Help...
  Citroen DS3 DSport
Have you been using a dual screen setup with your iMac?
Some advice if not from another forum:
What happens if you go into ~/Library/Preferences and delete the .plist file associated with that app?
This should do it, I just came in here to mention it. I've tried this with other apps when this has happened, and it works like a charm when nothing else did.
Sometimes you can also go under either a Window or a View menu and there will be an option to tile the windows, which may also work.
