Iv changed my Dogbone mount but still getting clunking noise? Any ideas?
Paddy_g46
Basically i was getting clucking from low gear acceleration and also somtimes if i hit a bump in the road. My gearstick was also moving back and forwards on and off throttle.
Iv just finished changing my mount but its still clunking! :( Good news is at least the gear stick is solid now!:clown:
Has anyone got any suggestions of what to check and how to check it?
Patrick
I changed mine for a powerflex one, but the knocking only went away when i replaced all the engine mounts
Have you checked the other mounts at all to rule those out?
not really mate, i grabbed the wheel when it was off the ground and tried to move it up and down to see if it was the top mounts but that was all i checked really.
What should i check next and how?
The main engine mount would be 1st to check, see how far you can move the engine by hand(back and forth).
I checked that earlier and i dont think it moves all that far, someone on clio16valver suggested checking the mount under the battery, if i take the battery and battery tray out what am i looking for? How will i tell if its shagged?
also if it is an engine/gearbox mount would it make sense that it makes a clunk when hitting a bump in the road?
change them all to be on the safe side mate as once you change 1 worn mount for new it then transferes the movement over to the other worn mounts, litteraly picking on the next weakest link. There not expensive and it transformes the car.
Ive got about a 2cm gap from the rubber bit to the metal bit which the mount sits in is this normal? an ive changed all my mounts and engine feels like its moveing about like mad and my gearstick flops about
