JC5 129 cup gear box, techy question
  Lionel Richie
anyone know how to dismantle one???
i've got the bellhousing and gear casing split, but can't get them apart fully
i'm stumped!!
  182>FRS>VX220 now 350Z
1. locate big hammer in garage...
2. take big hammer and hit bellhousing....
3. HARD.
Any help? :p :)
Its the same as the Williams one isn't it?
if so you cna download the guides on the WIlliams gearbox stripdown procedure from williamsclio (there a link somewhere for it)
  Lionel Richie
which one is that??? the bigger one with the selector held on by the big nut??? or the smaller one with the star bolt??
  172 cup'd extreme
5th gear is at the end , you take the cover off thats the final drive with the selector rod, i was watching the chap strip mine down , im sure he got the final drive off then it all came apart
  Lionel Richie
so final drive is the bigger one with the selector fork???
and 5th is the smaller one held in by the star bolt???
do you know if he removed the selector arm under the box??
  172 cup'd extreme
yeah he removed the arm, it wont come apart unless you do that.
final drive is the big ass gear when you take the white or black cap off the end of the box,
becareful of the plastic wheels in the box that drive the speed sensor there t***s to get back in if they fall out
  172 cup'd extreme
got the spring off? split the box enough to see the selector arm on the other side of the metal circlip un there i think, how many malbough lights you been through tonight ?
y0z2a said:
please don't break it! ;-)
if you do, don't do a Cutler!!!
/y0z
You know the only reason this topics turned up is because you've probably threatened him to stop using his grinder. He could have this stripped down if you let Fred go with the grinder (not saying you've be able to put it together again though).
  Lionel Richie
i just want to see the internals, and how they've responded to the abuse they've had!! the syncrhos are buggered anyway, i want to rebuild it, whether i have the ability is another matter!!!
  Lionel Richie
yeah, but business keeps getting in the way, i have no time to touch my car, i hope to have it done this year, hopefully for FCS
MarkCup said:
Is there anyway you could drop a shorter 5th gear in?
I could get a lot more out of mine on track if it actually pulled in 5th but as standard it's way too long.
yep 5th on a seperate bit of th box so it could be done relitively easily.
  MERCEDES CLS AMG
Fred - these are easier to play with than lego sets - what you need to know ??
