Just had mine done at Agency transmissions - for £350 (might have been £375??) for literally everything I decided I couldn't do it for less once I'd faffed about and bought/made tools. If I had like 5 to do do I would have done it. But no point for one.
Im thinking about rebuilding my JC5-130 gearbox and fitting an LSD. I was wondering if there is an in depth repair manual/guide for doing a gearbox rebuild and what/ if any special tools i would need.
TIA
Sound, cheers mate. Will let you if know if i decide to do it. But by reading these i probably wontBut if your adamant about doing the job your self, there is a Renault manual kicking about on the net and a few good threads which cover it well on other forums. I 'think' I might have a copy of the Renault gearbox procedure somewhere the computer. If you can't find it drop me a PM and I'll take a look. From what I can see its not rocket science at all, similar to any other FWD 5 speed from the era but some of the pullers are fairly specific - some people have succeed in modifying pullers however others have chipped gear teeth using them.
Eventually I just came to the conclusion that I had better things to spend time fixing on the car and it was nice to be able to get on with them while someone else sorted the box.
Just reading over this and what's the general cost of a gearbox refresh and a mod to take the Quaiffe or RSX diff. I have no problems with the gearbox but would want any known weak links changing before a diff went in.
The gripper has been worth at least a second a lap on my car,
Only compared to standard in my own experience, and I'm sure any difference over Quaife would be a lot less than a second.Compared to a Quaife, or standard open diff?
