Jeffs Acyrlic Jett Trigger Vs EGP
Whats better ?
Egp or Jetts Acrylic Trigger ?
And can the Acrylic can be used at this time of year as its a spray on wipe off ?
Which i think could be better than EGP which needs a cure time and would be no good this time of year:(
  106 GTi
Cost aside the sensible choice is the Jeffs, just down to ease of use and the fact you can layer it straight away with no cure time before removal or between layers, I can do three coats in the time it takes to do one of EGP. The Jeffs is as easy as using a QD spray.
I am not convinced it is as durable as the EGP but I have never tested it properly to comment.
Marky_
I went for jeffs. Only used it the once but is very easy to apply and when combined with jeffs carnuba seems to be pretty durable (haven't washed the car for nearly 2 months :quiet:)
  titanic killer
Good tip from Rich,'was to put some EGP in a sprayer and just mist a hand foam pad' works a treat:D
  106 GTi
Indeed - Less is best when it comes to the EGP, even when you get it on nice and thin it is still to thick, nice and thin and cured well and it wipes off easily, damp days are a no non.
LOL @ Ali - M Seal is proper shite !
  172 ph2
i used egp today and all i did was squirt it on a faracla polishing cloth so it was damp with egp and wipe over the paint using no presure.
Ali
  V6, Trackhawk, GTS
LOL @ Ali - M Seal is proper s**te !
meant to say jetseal... never tried M seal.
  Mito Sportiva 135
Jetseal is off the radar, want some but nowhere has it.
Only used it on the wheels but works great.
