Jerky after driving home in rain
ex-Chinese Dave
I drove home last night and from the start the car was perfect. I went through one large puddle, but not quickly and also there was a little standing water on the motorway. Once I came off the slip road I could feel that the car was very jerky below 2000 RPM. It starts fine and runs fine above 2000 revs. This morning I took off the inlet manifold and made sure there was no water down the plug holes. I didn’t see any moisture at all and I gave everything a good spray of WD-40. I’ve re-fitted everything and I’m now on a test drive, but I’m not convinced everything is perfect. The car is a 172 Cup and has just recently been fully serviced, it’s been running perfectly. Could it be something to do with the O2 sensor that may have gotten wet and will clear itself? I’m a little baffled as it wasn’t like I went driving through a river.
ex-Chinese Dave
I've checked the fuse box. Nothing looked damp but I took out the fuses and relays and gave them a squirt of WD. Hoping this will work later when I go out.
Under the car, on the passenger side, I could see some wires going into a connector. Do I take it that that is for the O2 sensor? I've given that a WD, too.
Matt Cup
  Leon Cupra
Does yours have the shield in front of the alternator? If it’s missing could water ingress there cause issues?
