cheers for all your help guys but rich, can u just give me a brief step by step guide on pc-ing, like, step 1: apply polish etc etc. An idiots guide if you will lol
cheers boys
There are loads of threads on this already, but a few hints:
1. Ensure the car is thoroughly cleaned (shampoo/ clay as necessary). The better you prepare the paint before PCing the better the results, from my experience.
2. Mask off plastics/ gaps between panels with 3M tape. Not strictly necessary but saves a lot of time after cleaning up.
3. Start of by using the lightest pad/polish combo and seeing how it comes up. Move more aggressive depending how you get on.
4. It is better to use too much rather than too little polish.
5. Do not PC in direct or bright sunlight.
6. Check your work regularly to ensure you are not causing any damage.
7. Spread the polish with the PC on a low speed setting. Turn up the speed once it is evenly spread, up to about 4 or 5 (Any faster and the vibration gets too bad anyway)
8. It is better to do a few passes over a panel then try pressing too hard on your first attempt.
9. Remember it is better to leave a few swirls that can be removed later than to remove paint or clearcoat that will need to be repaired. You probably won't get 100% of swirls out on your first attempt. My car was in good shape before PCing, but still a few minor ones on bonnet and roof I will go back to over the summer at some point.
Hope that helps. As said though, try searching through posts and come back if you have any more specific questions.
