what gauge cable are u using? ifs its too big, take off the rubber grommet, and give it a good squeeze through there. If that doesnt work, take a drill to it and make the whole slightly larger, that should do the trick.
how do you propose to take the gromet off? its not that wide its only 8 guage, i think i might be able to do it, but its gonna take mucho lub hope this dosent effect the bonnet cable!
hon you should know better than that son , need to put a grommet on even if the original one wont fit. otherwise, the wire will end up being cut by the harsh metal edge and will short out.
I carefully cut the grommet on my 16v [not sure what its like on yours ?] making it a bit bigger and fed the wire through from the car using a cut down coat hanger, worked for me and it meant no drilling ?
