Hello everyone,
I just picked up a silver Phase 1 Clio 172, with 105k on the clock from a local guy. I didn't pay too much for it, so it isn't perfect by any means.
It seems in pretty good nick (was owned by a mechanic), considering the miles but has a few of the usual faults. I am basically using it as a nippy runaround and commuting car since I have a Porsche 911 that is mainly for track work and my missus doesn't like to put miles on her Alfa - Don't ask! :S
Cosmetically the car seems ok... It had the bonnet do the flip-up thing, at speed (so did Lou's last Clio), so it has had that replaced but the roof still has a couple of dents in it, by the drivers door. The steering wheel is absolutely knackered!!!! As they all are... A couple of bits of trim need replacing, but I will get round to it.
I am loving it though! Seems a bit long geared and I need to really rev it to get it going, but it is very economical (trip computer says 36mpg for the 200 miles I've owned it) and brings a smile to my face everytime I am on the back roads. :evil:
It's being treated to a full set of new tyres all round in about 2hrs time, so that should be good! It is currently on 4 different ones, all varying makes, tread styles and depths! :dapprove:
My major questions at the moment are (though I will post them in the other sections/ faults etc if they are better in there) are:
1. Can anyone recommend a good garage in the SW London or Surrey area?
2. The car hunts and revs high at idle, when warm. Assume this is probably the idle control valve and that needs a clean as well as maybe the throttle body? Is that a common fault? Could it be anything else?
3. The steering wheel needs either replacing or re-covering. I have just bought a cover as an interim measure, but it would be nice to get a new one or have it re-covered. Can anyone recommend somewhere to do the re-trim? I believe new ones at Renault are aboyt £300 fitted, which seems expensive when they aren't likely to last long, right?
4. There is a vibration above 70mph from the wheel area, which I had assumed to be the balance of the dodgy wheels/ tyres. Since I am getting new ones put on today, i guess we will see if that cures the problem. Else, can anyone suggest whether it could be something else? I am thinking that it could be connected with...
5. I have to go up a multi-storey carpark to park at home. That means I mainly turn left under power. On full lock there is a real grinding sound coming from somewhere, under power (though not a lot as it is tight in there). I assume it is round the front wheels. Could that be connected with the vibration and could it be an/ the driveshaft/s? Is that a common problem or has anyone had these symptoms before?
Well, that list wasn't too long! LOL! It really is great and I am loving it, I am just a bit OCD about having these things sorted, especially since we need to do a London to NE Yorkshire and back trip in a couple of weeks! which has to be 4-500 miles round!
Many thanks in advance and I am looking forward to spending more time on here!
