Got mine done at BB when I was approaching 70k last year. They only charge about 160 quid which is reasonable and whilst you are at it they may as well do water pump if it needs it.
Good time to get cams or a chip fitted too as you would need belt changing on cam fitment. So in theory can put that 160 quid youd pay for teh belt change to teh cost of fitting the new cams and belt.
MY CAMBELT WENT TODAY!!!!! i cant belive it, i thought the fuel pump had cut out after i went over this ridge a bit fast but the RAC bloke took 5 seconds and said the cambelt had snapped!!!
And the most annoying part is that mine got changed less than a year ago!!! think it was on 57000 and there cars only done 69000!!!!
I couldnt be more pissed off total
Red Valver, i live in gillingham kent. may be talking to you later about repairs. its only a 1.4 8v so im hoping its not too bad. Dont think my revs were that high
I can recommend Toy (Redvalver). Helped me change my cambelt. Sounds to me like yours probably snapped due to being fitted too tight, if it only had 10,000 miles on it?
at 4k revs ur looking at all the valves valves being bent on the engine. mine went at 2k and bent 8 of them! the problem ur gunna ahve is getting a williams cylinder head second hand. if u rebuld ur existing head, itl cost a packet, 32mm williams valves r special order items from renault, and exhaust valves dont come in cheap.
