k&n cleaning/fitting
Car  Toureg vW Transporte
can i clean a K&N induction kit off in white spirits or anything like that?? also underneath theres 2 small holes? i presume 1s a breather pipe, whats the other, this is for a 1.8 16v
The other is for the idle speed control valve.
If you want to clean it use just use hot soapy water always going from the inside out, you can get proper K&N stuff for cleaning it and youll need some K&N oil once clean.
Mat.
cheers kids so if i fill the filter up with hot soapy water and just wait for it to seap through.
daf, i did this and the pipes are a tw*t to get back on
use some soap or fairy to get it back one
cheers lads, havent got car at the moment as its still being sprayed, im building an inclosed box for it so heat isnt a problem, thanx for the help deano and matt
