Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
The bolts the Clio Cup racers use fit a Mk1 but not a Mk2. I suspect K-Tecs are for the Mk1 so should be fine for your 172.
I had some made up for my Mk2 172, adding about 1 degree -ve camber on the front. Initial turn-in improved, but its a subtle change not a "phooar, what a difference!" type mod. What really helped was getting the tracking properly set up and fitting shims to the rear axle (-ve camber again) which really sorted out the stability of the rear.
Quote: What really helped was getting the tracking properly set up and fitting shims to the rear axle (-ve camber again) which really sorted out the stability of the rear.
do you have a link for that??
im with - 1.5º and im very happy, maybe next time i will go for -2º
