Kangoo van ABS problem
Hello all
This is my first post in here new to Clio ownership only been on here a month or so but I've got a problem with a van at work and hoping you can shed some light on it.
It's a 56 plate kangoo van 1.5dci. Showing a ABS ecu fault so replaced the pump as the ecu is integral on the diag it gives reading from all wheel sensors but still have a abs light on the dash and fault code 17 for abs that won't clear. I've been told by a few people in renault that the pump\ecu doesn't need programming but by 2 people outside of Renault that it needs programming.
Can anyone shed any light on the subject please
Chris
