KEROSENE
Kerosene is it the same as paraffin? And what would it be like in a diesel engine (forgot about the fuelling system E.G. pumps lines filters I'm on about the combustion side of the stuff.)
Is it much thicker then normal diesel and what cheap additive good I add to lube it up, Also to stop it solidifying when cold
By the looks of it. Most things are a by-product of petroleum (diesel,LPG,Kerosene,Jet Fuel).
Well jet fuel is Kerosene :)
So I had get Kerosene at 20p a litre :) so I ill run my car on that :) job done :)
i now for a fact the jet force or woteva is called jet car that poses at york runs on kerosene.
good enuff for them good enuff for owt
Turbines don't care though - no moving parts that rely on the fuel for lubrication - unlike a Diesel pump for example!
Best bet is to thin it down to circa Diesel fuel levels as if its way too thick its quite likely you'll shear the pump drive off.
Jet fuel is fine straight out the plane though.
M
