Key cuting???????????
  172 , looking for a 4x4 !
Hi,i was out battling my way through the christmas sales with my littlun this morning and popped into a key cutting shop as i only have one key for my 172 and was quite horrified at the outcome!!
The chap said they were a main dealer only affair and would set me back over £100.
Is this correct ??
If not where can i get a key done??
Liam
Is this correct ??
Liam
The key fob has a transponder in it that needs to be programmed. Renault job.
So basically i am screwed then:rolleyes:
Ill just make sure its on a bloody huge key ring then!!!
Do the batterys in the keys go flat very often??
£140 for a replacement key coded to the vehicle, as said will be alot cheaper just to get a blade cut but that won't start the engine, just take the steering lock off.
Wouldnt do me a lot of good though except let me winch the car on to the back of my truck to get it home!!!
As i said,ive not lost the key,just covering my bases!!
I will get a blade cut like you said though just so i can move the car if the worse comes to the worse!!
Liam
