Plugged in rs tuner for the first time and it comes up with knock sensor code. Also used my trust obii code reader which raised same code. No engine light.
Is it simply the sensor or could it be something else which sets sensor off?
At a pure guess.
Timing (who did the belts?)
Injectors.
Lambda.
R sport did the belts so I can assume this is all OK as that's all they do, renaults. I'll change the lambda as it's easy and tbh might aswell due to age of car. If no good I will get Rentech to have a look rather then chase.
Which car is this anyway?
Exclusive.
They are. And exclusives are a handy mishmash of ph1 and ph2 wiring diagramsPh1 may be different with regards pin connections.
