Knocking on O/S Front Corner
Car  421 Cammed 172
I've done a search on it but there's no definitive answer and not many people have the symptoms i'm avin.
Only the front O/S corner is knocking, It's not only when i turn, It's when i'm going slow also, hitting pot holes, speed bumps etc. Also does it when i'm turning.
Not my CV joint as i've just had that checked, re-greased and re-booted.
Could it be Suspension strut tops or ball joints?
I don't really wanna spend money on something it's not going to be.
Any tell tale signs to help diagnose the problems?
Thanks in advance.
Could only check with a rachet & socket as i didn't have any swan neck spanners to hand at the time.
Everything seems to be tight, but i'll dig out the swannies and give it a go.
It also does it when i wiggle the steering wheel while the cars stood still.
yeah mines the same, every time i pull away i get the clunking and knocking, pretty sure its the top mounts, have you lowered your car?
£50 per side at Renault i believe.
You should never give Renault the credit of parts value that you'd associate with other manufacturers.
They want £120+ for a plastic splitter!
It could be the bearing that's gone, I'm sure they can be bought seperate from Renault.
mine does the same its the bearins mate you can either go to a scrapy and buy a front hub and it comes with bearings so you just take old one off and fit new hub or you can just keep your hub take it off and press fit the new bearings its easier to just buy a hub from scrapy as fittin bearings are headache
I'm doin the brake sunday so while the wheels off i'll give the hub a shake top to bottom and see if it's iffy.
Any idea on price of the strut top bearings Da? I'm thinking of getting some Compbrake solid top mounts so if they'll sort it i'll probably go with those instead of the Renault shite.
Any idea on price of the strut top bearings Da? I'm thinking of getting some Compbrake solid top mounts so if they'll sort it i'll probably go with those instead of the Renault s**te.
From what i've been reading on here i wouldnt bother with Compbrake ones, ASTs, KTR, and mark fish seem to be the ones to go for
ASTs dont require any drilling either :cool:
just started having this problem, was told a few months ago my top mounts needed doing but i just thought it was national tyers trying to rip me off as there wasnt that much free play in them. But i guess they where right!!!!
Had the same on mine and after it going in to Renault twice and them saying it was the shock that had gone and changing it. (Was under warranty or would never have taken it to them)
It was still doing it so had a look myself and it was the ball joint. New ball joint was £8.50 and took me 1h to change. All good now.
