Koni rear damper fitting issues
Car  clio 172
Anyone else struggle fitting them ? Fitted the boot and bumpstop from the old suspension but struggling to get enough of the shaft and thread to get nut on.
I may have to get my dad to sit on rear tomoz to get some more weight in the back.
These are replacing the koni kw rears so may have to remove the boot / bumpstops from that rather than using the renault ones.
Just seems to be harder than it should 🤣
I sorted them in the end. I removed the boot and Bumpstop of the kw rears and all went together fine. I was struggling with the oem Renault ones so not sure if they are compatible or not.
