KONI shocks
Car  Clio Cup Ph2 172 16v
After looking through receipts I realise a previous owner installed KONI dampers and shocks worth over £500... :)
The car is lowered 30mm on Eibachs but I have just ordered 50mm springs for the front, will these fit in on the current suspension setup okay?I don't know much about suspensions to be honest, shocks are currently set to the softest setting,should I adjust this?If I stiffened it would it make a great difference to the handling?
Thanks, Aaron
Eibach springs and Koni dampers sounds like a pretty spot on setup to me! I'd leave it as is. What springs are you getting? Not a lot are held in high regard on here except the eibachs I think!
They are from a shop off ebay called abacus performance, probably not as good quality as eibach but i wanted to have the front a bit lower. I imagine I'll probably put the eibach's back in if ride quality is aweful :P
