Koni Sport (Yellow) Shocks
Can anyone confirm that Koni Yellows (adjustable) will fit a 182 Cup?
Part numbers (listing is for 172s) are 8710-1395 (front) and 8010-1048 (rear).
I'm pretty sure they will fit the 182 non-Cup (same struts as a 172) but can anyone confirm they will fit a Cup?
Cheers,
Anthony
172's and 182's have slightly different suspention the difference is the bolt hole spacing on the bottom struts - 58mm on 172 and 60mm on 182, all you do is grind out the bolt holes a bit to make them fit
So theres no difference apart from the bolt hole diameter?
I was told for Bilstein shocks something at the top of the shock has to be modified as well for a 182.
