ktec coilovers
Car  clio sport 182
Gonna be fitting a set of ktec coilovers to my 182 in the next couple of days. whats the best ride height to go for with 16'' wheels?
im planning on doing a couple of track days in it this year so would want a fast road/track setup.
Just phoned ktec theyve told me...
REAR: 10MM from underside of adjusting ring to the beam.
FRONT: 120MM from top bolt hole in strut to the underside of the spring platform.
This should give me a fast road/track setup.
Abit of usefull info if anybody needs it.:)
Useful info, I just set mine up so it was slightly nose down and was a height which I liked visually. The front rubs a little when I'm cornering hard and go over a dip in the road, but nothing too serious.
when fitting these coilovers do i need to use anything off the standard suspension? also do you remove the big rubber thing which sits under the suspension turret??
I still haven't fitted mine. Any idea how much I can lower front/rear by without hitting the splitter on speed bumps (effing London... :dapprove:)? I currently have stock 16s on.
Sorry for noobiness :P
