ktr solid top mounts
Car  corsa D / 172 clio
hi
i have fitted ktr solid top mounts and eibach proline springs to my 182.
the problem is when i go over a rough bit of road it sounds like they are knocking also i
have creaking noises when steering.
when i built the struts up as per the instructions it said to leave the nut that sits
underneath the top mount off so now there isn't a nut holding down the spring plate
to the spring.
have i done it right or should that nut be on?
if it is right could i get something made up that would put more pressure on the spring
plate and spring to tighten it all up and hopefully stop the noises?
i have purchased a diesel injector socket and some extra long hex keys along with a
breaker bar to really get them tight but they are as tight as they will go but still i get
these noises!!
any feed back will be much appreciated guys
cheers
chris:D
ahh right
never thought of that!
ive got so fixated on the struts never thought it might be something else!
thanks danny
if they are ok what next?
