Lacquer
Rojer
I sprayed the lacquer straight on never sanded it think the can is telling you lies!
  Ph1 172 + Combo van
If your paint is orange peeley or has overspray on it then it will feel rough and you can see it through the laquer after you have applied it. Best thing to do is to get a mild cutting compound on it and go over it gently to flat it down defore you lacquer it.
  260% JCW
You just give it a light sand with some scotchbrite. Nothing to rough, just enough to key it up for the lacquer.
  Punto/Clio GTT
if it dont need sanding dont sand it, just laquer it
if you have bits of crap, orange peel, roughness etc etc, just wetflat it lightly with fine paper, anything lower than P800 (p1000, p1200 etc) and apply the laquer to it. if you break through the paint, dust some more paint on, then laquer when its dry
