the pre-cat lambda (causes fueling and running issues bad mpg etc etc)
second one just checks to see if the cat is doing its job
you cant miss it, and the wiring to the lambda disconnects on the subframe which is a pain in the arse (has a piece of plastic it slides onto to keep it in position)
hard to explain lol i think its a 17mm spanner to undo the lambda itself
