lambda sensor misfire ?
Car  golf gti soon clio !
hi there
last night i was out for a drive i was in 2nd an 3rd i hit about 6.5k revs then changed in to 5th and sat at 70 on the motorway i went to over take a lorry so put my foot down a bit and the car seemed to judder n misfire you could hear it bog down and pop a bit then the car picked right back up after about 2 secs (this has happened once before it seems to be only in the WET and if you drive fast change at high RMP)
i was thinking about a doggy lambda sensor getting wet ??
any ideas
thanks
Mine missfired loads with no faults changed plugs leads and coil pack and it still did it, day later EML light came on, upstream lambda, changed that and all good
well i ordered a coil pack and ht leads and the spark plus only got changed 15,000 miles ago so should be fine if that don't fix it i will change the lambda because i think maybe the connection is getting wet , but iv now got an un steady idle to go with it
