boomerbang2006
clio 172,2001
Just a quick question,will a faulty lambda sensor ruin my mpg?
Where is the plug for the front one? I was having a snoop about for it but couldn't see it.
Thanks, might have a look if it ever stops raining!It's easier to see from underneath, as you would need to remove airbox and engine cover to get to it. Follow the wiring from the top GB earth as its branched off that.
Iirc the only difference between Pre and Post us the length of the sensor cable, otherwise they are the same.
b****cks looks like I've fitted a worse lambda sensor then![]()
I drove to barmouth and back from the west midlands yesterday with the new lambda and the start of the journey my mpg was 36.5,when i got back it was 38.2,so at least it works.
Oh really? That was the same as the one I replaced with, ph2 post cat into a ph1 pre cat so should be fine?
I was barely getting 21mpg now barely getting 16!
Which one did you replace?
The front one will be the one that affects the MPG performance.
The rear one will be the one putting your Engine management light on.[QUOTE
They replaced the front one(pre cat),thats what the diagnostics came up,are you telling me that i need the 2nd one replacing too?
