lamnda sensor spanner size
Car  clio 1.4RT
Hi anyone know ther correct size spanner i need to undo a lambda sensor on an old 1.4rt 98 mk1???
All help appriciated
Not to come across as a t**t but whats stopping you getting under the car and trying a few spanners?
22mm i was working at one last nite!! same as any other renault, ithink!!
it must be 22
but you dont need a spanner
you cantake it of with a 22 wrench
before doing it spray wd40 or something similar
HI,
The reason i wanted to know is that i do/did not have anything larger than a 19 spanner.
Cheers for the answer ...ill go and get a 22 and some wd40.
Does anyone know of a replacment lambda sensor i can get fairly cheeply.
