Clio Sport 172
Guys, traveled about 160 miles today, and after about 15 miles I could hear a rumble, i suspected a wheel bearing, and thought nothing of it (apart from which one and how hard to change)..parked it up after i travelled my distance and after about 3 hours i came back and moved it across the street and my brother pointed out a wet oil/grease/something patch on the road where my car was! I thought it was the suspect damaged wheel bearing from earlier which i thought had thrown grease everywhere? Popped a light under the car and found rear driver side damper wet with oil from where the smaller piston goes into the larger housing and all down the piston dripping onto the floor..does that mean its knackered? Do the dampers have oil in them? If so, what was the rumble? By the way, its a 02 172...
