its the two chasis rails if u pop ur head under ur car ull see two like triangle plates then just behind that ull see a square rail which is strong enuogh to jack ur car up on and leave it on axle stands
apart from where you put them, you just need to make sure the stands are OK and use solid, level ground
it's a good idea to leave something (spare wheels/wood blocks/etc) underneath the floor, just incase some idiot decides to try and push it over in the night (unless you're using a garage/secure land of course)
