LED interior light *SOLVED*
R
RyanWXM
I have fitted led lights into the interior light of my car and it work great but.... when it is off (doors closed) the led is on still very lightly. Is this normal, i don't think it would drain the battery but just wanna know if it can be solved
As said it won't drain your battery and it's fine.
To add more to this, I believe it is something to do with residual/low level current still being present in the circuit. It's normally due to there being a switch that's being powered or similar in the circuit. I believe in the Clio it's something to do with the interior light dimmer/fade.
It can also happens in household lighting using LED bulbs.
