interior is a 36mm festoon bulb you can get them off ebay for a decent price, the same in the boot too.
number plate light is not a festoon or a 501 i think it has one pin on the bottom:S
what is the size for mk2 ph2
i think its 36mm festoonwhat is the size for mk2 ph2
9Right im gonna buy sum of ebay how many LED's should i go for 6 or 9??
boot is 36 but 39 will fit, not 100% as mines a ph1 but the interior light on mine is also a 36mm festoon, if you have the map reading light then i think that is a sidelight bulb which is a 501, once again very cheap of ebay for the led versionsam i right in saying the boots light is 39mm, and not sure about interior as it is not festoon its just a bulb?
pop up pics when fitted, i've been thinking of changing my interior one for a while
Im really after the rear plate bulb over anything else.
Is it an R10W?
is yours a ph1 mk2 clio mate? i have had mine for a while and it doesnt work when you turn it on manually it just goes off. other than that its fine though. just wanted to know if yours does that too?Still doesnt look that bright... maybe because it is daytime
Btw, we need a guide on this!
Night pics needed!!
ill take pics now
Kind of in my garage!ill take pics now
Its dark near you?
