Led lights for Clio Mk4
I ran led bulbs in my ph1. With a decent set they were much improved. The problem with the headlight swap from ph2 is you need a custom loom I think, and I’m not sure many people make them anymore. Obviously if you can you could do it yourself.
Yeah I’ve been looking at replacing the bulbs for the low beam only , found some on Amazon but so many to choose from. May have to read a few reviews and make a choice. may Just leave the high beam as I think the other will probably do the work of both.
I upgraded both low and high beam to led just to have both the same. It was worth doing and looked and performed a lot better. However definitely get decent ones because of the beam on some is terrible.
Which brand did you go for and did you get any dashboard errors ?
I’m struggling to find the brand to be honest, but they weren’t really expensive ones. Even the cheap ones I tried didn’t throw any errors though.
